COMICA LAUNCHES GROUNDBREAKING STUDIO MIC LINE WITH INTEGRATED WIRELESS MODULE
Ejoy Uni Pro RGB Cardioid Condenser USB Microphone Supports Dual Wired/Wireless
Modes for Flexible Use with 48kHz/24bit Recording and Professional Studio Quality
Comes in Load-Bearing Boom Arm or Desktop Pro Models
August 9, 2024, Shenzhen, China -- Comica Audio www.comica-audio.com, a leading professional broadcast-level audio company, launched today the Ejoy Uni Pro studio mic with a built-in wireless RF module, a groundbreaking mic with USB-C receiver that combines dual 2.4GHz wireless and wired modes with professional studio quality sound for gaming and streaming allowing users to choose a wired, wireless, or dual mode connection according to different needs
with a wireless transmission distance of 20 meters.
The Enjoy Uni Pro captures high-resolution 48kHz/24bit rich detailed professional studio quality audio for highs and lows with a clear real timbre with a built-in sound card compatible with various operative systems and applications, so it can be used without an extra device driver. The mic supports real-time monitoring and pick-up, with a one-touch denoise button for clean sound and a mute button to quickly respond to accidental noises and avoid picking up external voices. In addition to the denoise and mute button, noise is also reduced through the shock mount that reduces vibrations caused by accidental bumps and a metal pop filter that filters out air flow noises.
The Ejoy Uni Pro studio mic is available immediately, perfect for gaming, teaching, voice recordings, streaming, interviews, videos, podcasts, presentations, church and wedding services, social media posts, and video conferencing.
Ejoy Uni Pro (D) Desktop Version
Ejoy Uni Pro (A) Adjustable Boom Arm Version
Available in Adjustable Boom Arm & Desktop Versions
The studio mic is available in two versions:
Ejoy Uni Pro (A) Adjustable Arm Version: features a full metal boom arm with a load capacity of up to 1.5kg (3.3lb), which is adjustable in all directions to record at different angles without loosening or shifting the microphone, even after hours of use.
Ejoy Uni Pro (D) Desktop Version: features a solid metal base mic stand with a non-slip silicone pad, which stops vibrations caused by bumping it.
In addition to the Pro versions, there is a basic Ejoy Uni also available without the wireless module.
Ejoy Uni Pro Features
A group of electronic devicesDescription automatically generated
A group of different types of microphonesDescription automatically generated
Ejoy Uni Pro (A) Adjustable Arm Version Ejoy Uni Pro (D) Desktop Version
EJoy Uni Pro Features:
48kHz/24bit recording with professional studio quality.
MicrophoneTX mute touch key.
Supports gain control, monitoring, one-key denoise, and mute with power switch/denoise/pairing key.
Dynamic Radiant RGB light with 3 unique RGB effects with RGB light power/effect switch/pairing key.
Receiver (RX) with USB-C interface.
3.5mm TRS/TRRS headphone port for real-time monitoring.
USB-C charging/digital output port: Charges the mic with a power bank/DC power supply.
via the 2-in-1 charging/output cable or connects to devices for audio output.
Gain/volume adjustment knob: Use the orange scale in the center as the standard; rotate left to decrease the mic gain and headphone monitoring volume; rotate right to increase the mic gain and headphone monitoring volume.
Long Battery life: in wireless mode, with the RGB lighting effect turned off, the battery life is up to 50 hours. With the RGB lighting effect turned on, battery life is up to 20 hours.
Built-in Plug and Play sound card.
USB-C digital output, universal for smartphone/computer.
Unique shock mount and metal pop filter.
(A) model: Includes an adjustable boom arm that holds up to 1.5kg.
(D) model: Equipped with a desktop mic stand and flexible extension.
Ejoy Uni Pro Applications:
A person wearing headphones and using a computerDescription automatically generated
A person sitting at a desk with a computerDescription automatically generated
Gaming Teaching
A person with headphones looking at a tabletDescription automatically generated
A person looking at a phoneDescription automatically generated
Recording Livestreaming
The EJoy Uni Pro line is available immediately in black or white, priced at $69 for the EJoy Uni Pro (A) Arm Version at: https://geni.us/D3wvg4T and $63 at the EJoy Uni Pro (D) Desktop Version available at: https://geni.us/qmmC0vB. The standard wired version EJoy Uni (A) with arm is available for $49 at: https://geni.us/PqOLZ and the wired (D) desktop version is $45 at: https://geni.us/m3VF. For more information, see www.comica-audio.com.
A black letter on a white backgroundDescription automatically generated
New posts
