With the new AI integration of Microsoft Copilot and PowerPoint, you can quickly generate detailed presentations with speaker notes from your documents.
Step-by-step:
Step-by-step:
- Launch Microsoft PowerPoint and select the 'Copilot' option from the top right corner.
- Describe what you want to make in the prompt box. You can choose to make a presentation from the beginning, upload files to create one, or make separate slides.
- Suggestions from the copilot are based on what you enter. You can choose to accept, adjust, or ignore the suggestions.
- Copilot has the ability to modify layouts, add images, create speaker notes, animate slides, and perform other tasks through chat conversations.
