Guide Using MSI Afterburner and HWiNFO64 at the same time with RTSS
DarthGorsoy
New member
Hello Social.
Most of us use MSI Afterburner for the easiest access to in-game performance stats. MSI Afterburner's interface with performance monitoring settings is both simpler and easier to customize. Rather than fully utilizing HWiNFO64's complex options, I'll show you how we can share the basics through Afterburner and other component values like PCB or VRM MOS temperatures through HWiNFO64.
First, let's open MSI Afterburner, click on the settings icon and follow the steps:
Then click on “monitoring” and leave the settings you are already using in this section, just click on “...”
Just check the box named “HwInfo.dll” and then click OK.
We are done with MSI Afterburner, let's move on to HWiNFO64.
Click on "Sensors" tab
Click on the "Settings" icon
Click on the "OSD (RTSS)" tab
In this section you can add the stats you want to show. Note that, you need to have the “sensors” tab always open to see this value. You can make the app invisible by pressing the Minimize button. This way it will continue to run in the background.
