XP-Pen Deco Mini7: A Beginner's Friendly Graphics Tablet - First Impressions
Greetings!
I'm here to share my initial impressions of the XP-Pen Deco Mini7 graphics tablet. Now, let me be upfront: I'm no expert in this field. I just wanted to share some thoughts.
Technical Specifications:
  • Active Area: 177.8 x 111.1mm ( 7.03x4.37 inches )
  • Weight: 307g
  • Stylus: Battery-free Stylus P05D
  • Tilt (inclination): 60 degrees
  • Shortcut keys: 8 on the tablet + 2 on the pen
  • Pen pressure sensitivity: 8192 Levels
  • Resolution: 5080 LPI
  • Reading height: 10mm
  • Cable port: Type-C
First Impressions:
  • Compact: This graphics tablet is the size of a small notebook. This makes it ideal for those with limited space or who want to use it on the go.
  • Easy setup: I plugged it into my computer and was able to start using it right away. I also downloaded the driver in two minutes.
  • The pen feels good in your hand: It's lightweight and comfortable to hold, just like a nice pen. The fact that it doesn't need batteries is a huge plus.
  • Android compatibility: It works seamlessly with Android drawing apps like ibis Paint X and Sketchbook. You use the tablet vertically while on your phone.
Experience:
  • Pressure sensitive: The harder you press, the thicker your line, just like a real pen! This allows you to create thin lines for fine details and thick lines for shading.
  • Smooth surface: The drawing surface feels nice and the pen glides over it smoothly. No shaky lines!
  • Shortcut buttons: There are 2 buttons on the pen that you can assign functions to, such as eraser or undo. There are also 8 customizable shortcut keys on the tablet.
  • Note-taking: It's also a great product for note-taking and solving PDF tests. I had no problems using it with Microsoft Journal and daily note-taking apps.
Additional:
Conclusion:
The XP-Pen Deco Mini7 is a great starter tablet for aspiring digital artists. It's affordable, easy to use, and pressure-sensitive, allowing you to create amazing drawings. The compact size makes it perfect for portability. If you're a beginner who wants to try digital art and not break the bank, the XP-Pen Deco Mini7 is a fantastic option.
New posts
